You need to remove the turbo charge hardpipe to reach the clamp that holds the accordian to the turbo inlet. it's worth the time to do it because it's a common place for boost leaks. I suggest replacing the stock clamp with a wide "t" or spring tension clamp for better sealing. Sorry no pics but good luck
